صفحة 5 من 5 الأولىالأولى 12345
النتائج 25 إلى 27 من 27
  1. #25
    الموضوع بالكامل هنا:
    WOLFSBURG, Germany — It's not as if you are ever going to be in a position to use your Volkswagen Touareg V10 TDI to pull a Boeing 747 out of a ditch.
    But the German automaker thought it would be an interesting exercise to see if such a feat is even possible. At the very least, it made for some interesting photos.
    The event took place at the Dunsfold Aerodrome in England. To make the Touareg able to tow the plane, VW engineers first increased the SUV's weight so "the power of the engine [could] be converted into propelling force." Steel balls and steel plates were distributed in the SUV for an additional weight of 9,579 pounds. The total weight of the Touareg in this case amounted to 15,498 pounds.
    Other modifications included increasing air pressure in the standard Michelin tires, limiting the maximum speed of the vehicle to protect the tires and replacing the V10 TDI transmission with the transmission of the Touareg V8.
    An extra device was used to hook up the plane to the standard trailer hitch. "Based on the maximum torque of the V10 TDI (550 pound-feet) and the transmission ratio, the engineers had previously calculated that the Touareg would be able to put approximately 200 tons into motion," said VW in a statement.
    Turns out they were correct. With the four-wheel-drive control in the low setting and the automatic transmission in 2nd gear, a VW technician was able to perform the feat. The plane and SUV traveled 492 feet before coming to a stop — and the company reported that a check of the Touareg did not find "any evidence of damage to the car."
  2. #26
    Prelude 4 Life غير متصل مشرف سابق
    30
    2,771
    اقتباس المشاركة الأصلية كتبت بواسطة 1100R
    سؤال::اذا افترضنا ان القير تحمل..كيف الفرامل قدرت توقف السيارة ووراها وزرن زي هذا؟؟؟
    اكيد يقدروا يستخدموا فرامل الطيارة نفسها لايقافهم
    على العموم السرعة كانت بسيطة جدا وماتحتاج انهم يستخدموا فرامل... بمجرد مايرفع السايق رجله من دواسة البنزين راح يوقفوا
  3. #27
    الصورة الرمزية مؤيد اف1
    مؤيد اف1 غير متصل عضو فعّال
    798
    بعد رفعو وزن السياره الى فوق 9000 باوند عشان القوه من المحرك تخرج متناسقه وبالتدريج
    رفعو ضغط التواير + حطو جير ال8 سلندر بنسب مختلفه..
    صج ان المان
  1. فولكس واغن طوارق بتعديل JE Design
    آخر مشاركة: 18-03-2011, 05:02 PM
