    16,950
    افتراضي THE ALL NEW ASTON MARTIN VANTAGE 2018
    Replacing a car like the previous-gen Vantage is an incredibly difficult task since that model was universally praised for its drop-dead gorgeous looks but Aston Martin has made it look easy with the breathtaking new Vantage.
    Everything is new on Aston Martin’s latest sportscar, from the chassis to the powertrain and from the onboard technology to the clever aero agenda.
    Power comes as expected from the
    AMG-sourced twin-turbo 4.0-liter V8 that here makes 503hp (510PS) and 505lb-ft (685Nm) of torque. Paired to it is an eight-speed ZF automatic transmission, with Aston Martin hinting at a manual option later on.
    Aston Martin says they’ve mounted the engine as low and as far back as possible to ensure optimal center-of-gravity and that perfect 50-50 weight distribution. Dry weight is an impressive 1,530kg (3,373lbs). 0-60mph comes in 3.5 seconds (0-100km/h in 3.6) while top speed is 195mph (313km/h).
    The chassis is an evolution of
    the DB11’s aluminum structure, with Aston Martin claiming that 70 percent of it is new for the Vantage. The rear subframe is now solidly mounted to make the driver feel more connected while the suspension employs double wishbones at the front and a multi-link setup at the rear. The latest generation of active dampers are also present, offering three modes: Sport, Sport Plus and Track.
    The new Aston Martin Vantage is also the company’s first model to use an electronic rear differential (E-Diff). Linked to the vehicle’s electronic stability control system, the new differential adapts its characteristics much more cleverly than a conventional LSD, making the car feel more composed, both on a straight line
    and while cornering.
    “Creating a worthy successor has been a challenge to relish and a huge source of motivation,” said Dr Andy Palmer, Aston Martin boss. “I’m enormously excited by what we’ve created: a new Vantage that’s more explicit in looks and intent, wrapping heart-pounding performance and dazzling dynamics into an everyday usable package. A true sports car with a sharper look and a keener dynamic edge, the new Vantage is the Aston Martin pure driving machine enthusiasts have been waiting for.”
    Aerodynamics was also a key point to the design of the new Vantage; Aston Martin was able to employ all the latest tricks without littering the car’s curvy bodywork. The front splitter is designed to direct airflow underneath the car, with the floor featuring special channels to continue guiding it into the right places and of course make sure that the airflow into the rear diffuser is clean and uninterrupted. Even the new side gills are designed to bleed air pressure out from the front wheel arches while the rear deck lid produces “a significant level of downforce”.
    Aston Martin has opened the order books for the all-new Vantage today; prices start from £120,900 in the UK, €154,000 in Germany and $149,995 in the US. The first cars are expected to be delivered during the second quarter of 2018.
    16,950
  1. Aston Martin V12 Vantage
    آخر مشاركة: 06-06-2010, 03:57 AM
  2. 2010 Aston Martin V12 Vantage
    بواسطة BuSha6zZ في المنتدى قسم السيارات العام
    آخر مشاركة: 07-02-2009, 07:53 PM
  3. Aston Martin V12 Vantage RS Concept
    بواسطة الظهوري في المنتدى قسم السيارات العام
    آخر مشاركة: 27-02-2008, 05:36 PM
  4. Aston Martin Vantage V8 بتوقيع Loder1899
    بواسطة SuperXT في المنتدى أخبار السيارات
    آخر مشاركة: 20-11-2006, 01:44 AM
  5. Aston Martin Vantage V8 roadster
    بواسطة DRAGON في المنتدى قسم السيارات العام
    آخر مشاركة: 08-08-2006, 01:37 AM
