    16,942
    افتراضي THE ALL NEW LAMBORGHINI URUS 2018
    Lamborghini has officially re-entered the SUV sector, as their brand new, high-performance Urus SUV looks ready to slay any and all opponents in its segment.
    According to Lamborghini, the Urus' 4.0-liter twin turbo V8 engine will help it fit in perfectly alongside the Aventador and the Huracan, and based on sheer numbers alone, it's easy to understand why.
    With 641 HP (650 PS) and 627 lb-ft (850 Nm) of torque at its disposal, the Lamborghini Urus is able to hit 62 mph (100 km/h) in 3.6 seconds, 124 mph (200 km/h) in 12.8 seconds, and a top speed of 190 mph (305 km/h). A plug-in hybrid option will be available later on.
    The power hits all four wheels with the help of an electro-hydraulically controlled 8-speed automatic transmission, while a torque converter goes on to boost the twin turbo V8's response. The torque split on the four-wheel drive system is 40/60, with a maximum 70% of torque reaching the front wheels on demand, or as much as 87% going to the rear.
    Speaking of which, the Urus borrowed the Aventador S' rear-wheel steering system, set to utilize counter-phase steering at low speed and in-phase steering and high speed - the former aiding maneuverability, the latter stability.
    Also, in order to achieve a performance-oriented center of gravity, Lamborghini mounted the Urus' turbocharged engine low, while also placing the central turbocharger near the combustion chambers, thus enhancing engine response.
    Once you get the Urus moving, you can choose between its six drive mods: Strada, Sport, Corsa, Neve (snow), Terra (off-road) and Sabbia (sand), plus a custom mode called Ego. Neve, Terra and Sabbia will all raise the chassis of the car in order to improve ground clearance, while Strada, Sport and Corsa will optimize performance for the street and for
    various levels of sporty driving.
    Now that we've covered performance, let's talk about looks, since you know, there's no way around how aggressively-styled the Urus is. First, we should mention that it measures 5,112 mm (16.77 ft) in length, 2,016 mm (6.61 ft) in width and stands 1,638 mm (5.37 ft) tall. To put that into perspective, a Mercedes GLE Coupe is 4,918 mm (16.1 ft) long, 2,003 mm (6.57 ft) wide and 1,720 mm (5.64 ft) tall. Meanwhile, the Urus also has a larger wheel base than its rivals, measuring 3,003 mm (9.85 ft), and weighs just under 2,200 kg (4,850 lbs) - less than a Cayenne Turbo, with which it shares its MLB EVO platform.
    Even though Lamborghini says the Urus took some
    cues from the LM002, what you'll mostly see when looking at it are its supercar-like proportions where you've got the same "2/3 body, 1/3 window" ratio you get in the Aventador or Huracan. Perhaps just as striking as the diagonal hood lines or the large air intakes, are its sleek front lights, standing horizontally and featuring LED DRLs in the automaker's traditional Y shape.
    Move towards the rear and you'll undoubtedly notice the low roofline, frameless windows, strong rear shoulders and
    Y-shaped taillights. The rear diffuser was actually inspired by Lamborghini race cars, and packs integrated double round exhaust pipes.
    Once you're done admiring the exterior, stepping into the cabin means reflecting on an interior design meant to channel both luxury as well as performance. Just like other Lamborghini models, the Urus also features
    multiple hexagonal elements within the dashboard. It's also got a three-spoke steering wheel with vibration damping, a fully digital TFT display, High Beam Assistant, parking sensors, a PreCognition system (preventing/mitigating crashes), plus driver and front passenger 12-way electric heated seats (optional 18-way adjustable front seats). Since this is technically an SUV, Lamborghini will have you know that you can extend the trunk space from the standard 616 liters (21.7 cu.ft) all the way to 1,596 liters (56.3 cu.ft) by lowering the rear bench seat.
    As for the "finer things", the Urus' LIS infotainment system is able to recognize voice commands and allows users to fully integrate their Apple or Android smartphones via Apple CarPlay or Android Auto. Sound-wise, you get an 8-speaker system as standard, although a high-end Bang & Olufsen sound system with 3D sound and a 1,700 watt output is available as an option.
    Prices for the Urus start from $200,000 in the US (£131,500 UK / €171,429 Europe / RMB 3,130,000 China), while first deliveries are expected in Spring of 2018.
    16,942
    16,942
  1. THE ALL NEW BMW X3 2018
    آخر مشاركة: 25-06-2017, 05:18 PM
  2. تسريب صور لامبورغيني URUS SUV
    آخر مشاركة: 22-04-2012, 08:35 PM
  3. لامبورغيني وأنباء عن تحضير سوبر كار Urus
    آخر مشاركة: 02-12-2009, 07:27 PM
  4. جديد لامبورجيني .. Urus بـ 4 ابواب
    بواسطة Porsche Stuttgart في المنتدى أخبار السيارات
    آخر مشاركة: 26-09-2008, 04:28 PM
  5. Lamborghini Gallardo & Lamborghini Murcielago LP640
    بواسطة الحوت في المنتدى قسم السيارات العام
    آخر مشاركة: 02-05-2007, 11:26 PM
