    16,944
    افتراضي THE ALL NEW HYUNDAI VELOSTER 2018
    Hyundai revealed the new generation of the Veloster at the Detroit Auto Show, bringing a fresh design to match its quirky bodystyle.
    The
    new Hyundai Veloster feature the same, two-plus-one configuration known from its predecessor, having an additional passenger rear door for easier rear-seat access. The front end is dominated by the bold new grille design while the rear end features a big diffuser with twin tailpipes coming out of the middle.
    Base Veloster models will be available with a 2.0-liter four-cylinder engine that makes 147hp and 132lb-ft of torque that’s paired to either a six-speed manual or an optional six-speed automatic transmission.
    Go for the
    faster Veloster Turbo and then you get a turbocharged 1.6-liter four-cylinder with 201hp and 195lb-ft of torque. There’s an overboost function too, which raised peak torque to 202lb-ft. Customers will be able to choose between a manual six-speed or a seven-speed dual-clutch transmission.
    All models of the new Hyundai Veloster come with Torque Vectoring Control, which operates through the electronic stability control and wheel-speed sensors to apply precise braking in order to improve handling.
    Turbo models also get a quicker-ratio steering rack with revised calibration to match the higher performance. The new Veloster Turbo also gets a 24mm front stabilizer bar with the rear multilink suspension featuring a 19mm stabilizer bar to further control body roll.
    The range of driver-assist systems includes Forward Collision-Avoidance Assist, Lane Keeping Assist, High Beam Assist for the available LED headlights, and Driver Attention Warning.
    Inside, the new Hyundai Veloster comes with an eight-inch infotainment system with Android Auto and Apple Car Play, rearview camera, wireless charging for mobile devices, a head-up display and the company’s Blue Link connected services.
    Production of the 2019 Hyundai Veloster begins this March in Korea, with the first US-spec cars to become available during the second quarter of 2018.
    16,944
    16,944
  1. هيونداي فيلوستر توربوموديل 2016 Hyundai Veloster Turbo test drive
    بواسطة زورو الامارات في المنتدى تجارب السيارات
    آخر مشاركة: 14-04-2016, 12:45 AM
  2. Veloster هايونداي فولستر وارد كوري
    بواسطة Owies_Ax في المنتدى قسم البيع والشراء
    آخر مشاركة: 17-12-2013, 03:08 PM
  3. حصريا :: Hyundai Veloster 2012
    بواسطة IS300 في المنتدى المواضيع الحصرية والتغطيات المصورة والتجمعات
    مشاركات: 11
    آخر مشاركة: 01-10-2011, 08:10 PM
  4. 2012 Hyundai Veloster
    آخر مشاركة: 27-01-2011, 11:47 AM
  5. هايونداي HND-3 Veloster...........(جديد سيؤول)
    آخر مشاركة: 07-04-2007, 03:47 PM
