    Arrow CARVER ONE ........(جديد جنيف)
    PRESS RELEASE: CARVER ONE -The 77th edition of the Geneva Motor Show will feature the world premiere of the production model of the Carver One. Carver Europe, together with Carver Switzerland will kick off this year’s edition with a press conference on 7 March. Members of the press are invited to join us at our stand. From 8 to 18 March all Carver enthusiasts are welcome on our stand in Hall 3 (3112).
    Steer it like a car...
    … and it banks like a motorcycle. The Carver One feels just as much at ease carving corners, conquering roundabouts and beating traffic jams, as it does on curvy country roads or endless straights, far away from the world and its worries.Its sporty engine gives it just the right power in proportion to its weight, reaching a top speed of 185 km/h (115 mph) while its average fuel consumption remains at a very modest 6 L/100 km (40 UK mpg). But speed on the straights isn’t everything... Go for the corners, that’s where the Carver One pulls out all the stops!
    It banks from left to right in just a second. This unrivalled agility lets you cope with any emergency situation, avoid obstacles, and makes for sheer exhilarating fun. And what fun it is: virtually unrestricted manoeuvrability, surfing through traffic, snowboarding roundabouts and pivoting corners. It is like riding your own roller coaster designed as you carve along. It is like flying a glider at ground level. It is like playing the lead in your own version of Top Gun. It is all this and much, much more. When you fly a Carver One the journey becomes the destination.
    Stunning looks
    It will come as no surprise: developed by aeronautical engineers, form follows function in every aspect of its design. A timeless, distinctive masterpiece with razor-sharp lines, not only for its astonishing looks but also for perfect aerodynamics.
    The superb jetfighter-like cockpit comes in any manufacturer colour or custom colour of your choice, hiding the integral welded steel chassis providing safety for you and your passenger. The front window seamlessly merges with the body-coloured roof panel that can be easily detached to enjoy a panoramic view from all angles.
    Its sporty 15” alloy rear wheels with large tyres keep the Carver One firmly glued to the road in the corners and on the straights. The uniquely designed front wheel attachment provides the 17” wheel with exceptional road handling and superb manoeuvrability. Two seamlessly integrated louvered air intakes on either side of the cockpit feed the engine extra cooling air and add a zest of futuristic elegance.
    … and an interior to match
    Sporty, yet stylish, the Carver One fits you like a glove. The intoxicating smell of its luxuriously soft leather interior invigorates you as you enter the sanctuary of your cockpit. Your fingers explore the contours of the driver’s seat, the sports leather-covered steering wheel, the dashboard curves … prelude to the curves of the road that will soon unfold. Your hand rests on the aluminium gear lever knob, your eyes wander over the ergonomically laid out dashboard until they focus on the tilt angle indicators, anticipating excitement... This is as close as you may ever get to flying. Are you ready for take-off?
    A masterpiece of engineering
    Carver engineers may not be the only ones to have tried to overcome the problem of a narrow vehicle cornering without tipping over, but they are the first and only ones to have pulled it off successfully. The combination of state-of-the-art components and innovative but proven technology has resulted in a reliable, predictable and above all extremely responsive system, nothing short of a revolution in automotive history!
    At the heart of the Carver One lies the Dynamic Vehicle Control (DVC™) system which automatically adjusts the tilt angle of the cockpit to the speed and acceleration of the vehicle, enabling a plane-like ‘tilting before cornering’.
    A uniquely designed steering torque actuator coupled to an ingenious DVC™ manifold driving two double piston cylinders form the essence of this mechanical-hydraulic system while an additional separate hydraulic system provides for a fail-safe emergency backup solution.
    Power assisted front wheel steering and active rear wheel steering make for unparallelled stability when cornering. The DVC™ control unit electronically moderates the cockpit response at low speeds for comfortable road handling under all circumstances.
    To top it off, the DVC™ mode selector, a sophisticated piece of programming, allows you to select a driving mode according to your mood and road circumstances. In comfort mode, weaving your way through busy city-traffic and parking is easy thanks to enhanced power steering while the sport mode lets you unleash the rebel once you get the knack of carving.
    'Steer it like a car and it banks like a motorcycle'. It sounds deceivingly simple. And it truly is. All you have to do is steer in the desired direction. With the Carver One, banking in corners becomes second nature, or rather, first nature regained.
    Specifications
    Performance
    Top speed 185 km/h (115 mph)
    Acceleration 0-100 km/h (62 mph) in 8.2 s
    Max. tilt angle 45°
    Max. tilt speed 85°/s
    Turning circle (curb to curb) 9.5 m
    Fuel consumption (estimated average) 6 L/100km (1:16 - 45 UK mpg - 40 US mpg)
    Engine
    Cylinders / valves 4 cylinder 16 valve turbo intercooler
    Displacement 659 cc
    Cooling water-cooled
    Max. power 50 kW (68 bhp) at 6,000 rpm
    Max. torque 100 Nm (74 lb.ft) at 3,200 rpm
    Transmission 5-speed manual & reverse
    Fuel lead-free EURO
    Emission system catalytic converter with oxygen sensor
    Electrical system 14 V / 32 A alternator, Volts 12 V / 30 Ah battery
    Ignition ECU multipoint injection with knock sensor –
    firing order 1-3-4-2
    CO2 emissions 136 g/km
    Wheels, tyres, suspension and brakes
    Wheels double 5-spoke alloy
    front 17”
    rear 15”
    Tyres
    front 140 / 70
    rear 195 / 45
    Brakes discs on all wheels
    Front suspension single-arm with hydraulic shock absorption
    Rear suspension McPherson suspension with rear-wheel steering
    Dimensions
    Length 3.40 m
    Height 1.40 m
    Width (tilt angle ≤ 25°) 1.30 m
    Width (max. tilt angle) 1.60 m
    Wheel base 2.70 m
    Fuel tank capacity 34 L
    Unladen mass 643 kg (1,418 lb)
    The table above details the European specification Carver One, which may differ from Carver One models made available outside Europe. For example, for the North American market the Carver One will be equipped with a different engine. Please note that non-North American vehicles are not certified for use in North America.
    The package
    The list below gives you an overview of our standard package and currently available accessories and options. Contact your local dealer if you need more information or if you want to discuss any additional options. Special options are available upon request.
    Standard package
    Removable hard top roof in body colour
    Alloy wheels - double 5-spoke - front 17" / rear 15" (silver)
    Sports interior (black fabric trim)
    3-spoke sports leather-covered steering wheel
    Design aluminium dashboard and gear lever knob
    4 instruments: speedometer and mileometer (odometer), rev counter, fuel gauge, engine temperature
    Built-in class III remote control alarm system incl. remote control power door lock
    Dashboard 'carving' LED indicators (continuous indication of the vehicle's tilt angle) with audible signal
    Heating / ventilation / windshield defroster
    Electric windows
    Front and rear seat belts
    Ashtray / drink holder / 12 V socket
    Tyre repair kit
    Black carpet with Carver logo
    Side mirrors and back of driver's seat: black
    Exterior colour - basic palette (white, yellow, blue)
    Factory-fitted options
    Premium quality full leather (mono-colour or bi-colour) or leather/alcantara interior upholstery
    Exterior ****llic paint (standard palette)
    Special exterior colours (solid black, stealth black (matte black), pearl, or any manufacturer colour or custom colour of choice)
    Rear spoiler
    High power wheel pack (alloy - dark silver)
    Shadow wheel pack (alloy - matte black)
    Black package (matte black rear frame, tilt cylinders and front suspension)
    Turbo pressure dashboard gauge
    Radio/CD/MP3 player type A, B or C (Kenwood) with 4 front speakers (Kenwood)
    GPS navigation with Bluetooth™ mobile phone hands-free kit (Tom Tom Go 910)
    DVC™ mode selector (comfort/sport)
    Accessories
    Rear spoiler
    Roll-up soft top (black)
    High power wheel pack (alloy - dark silver) excluding tyres
    Shadow wheel pack (alloy - matte black) excluding tyres
    Aluminium luggage rack with luggage bag (waterproof fabric, black)
    Engine ECU tuning to 85 bhp
    Battery charger
    Service & warranty
    The Carver One is sold and serviced worldwide through a network of specialised distributors and dealers. The recommended service interval is 10,000 km (6,200 miles) or once every year, whichever is sooner. Servicing and maintenance is taken care of by your local distributor. Contact your dealer for more information. In the absence of a distributor in your country, servicing and maintenance can be arranged through Carver Headquarters. In Europe, the Carver One is covered by a 2-year factory warranty.
    Price
    Due to tax differences and transportation costs prices differ from one country to another. For country-specific pricing information go to 'Our dealers' and select the region and country of choice.
    The Carver One has been granted full European type approval and various initiatives to obtain certification outside Europe have been launched. In Europe, a car driver's licence is required to drive a Carver One. In the USA most states require either a car licence or a motorcycle licence. Please note that non North-American vehicles are not certified for use in North America. For tax purposes the Carver One is registered as a motorcycle in most countries.
    الصورة الرمزية بوجاسم
    بوجاسم غير متصل عضو شرف
    Dec 2006
    قطر الخير-دوحة العرب
    1,328
    ياسلام روعة
    شفناها على شوارع دبي ...وفيه وكيل لها اهني وسعرها ب170 الف درهم
    حجمها حجم سمارت بس اطول منها.
    سعر 170 الف درهم
    فكره تصميمها رائعه .. خصوصا حركة الإلتفاف!
    أعتقد شفتها مره في دبي وصورتها بس الصوره ضاعت للأسف .
    for ever 21 غير متصل عضو نشيط جداً
    الامـــ بوظبي ــــارات
    379
    بس غاليه وايد وما يسوى عليها ابصراحه
  1. مشاركات: 3
    آخر مشاركة: 25-10-2011, 05:51 PM
  2. بيجو EX1 الإختبارية.........(جديد جنيف)
    آخر مشاركة: 22-09-2010, 01:52 AM
  3. لوتس ايليت 2014........(جديد باريس)
    آخر مشاركة: 21-09-2010, 08:53 AM
  4. بنتلي تكشف عن كونتينينتال GT........(جديد باريس)
    آخر مشاركة: 08-09-2010, 09:39 AM
  5. جديد : كــامـارو اس اس vs ls3 مــوســتنق شــلبـي .... (( الرياض ))
    آخر مشاركة: 07-09-2010, 09:06 AM
