    Arrow هوندا تقدم كروس رود.............(جديد اليابان)
    Key Features of the Crossroad
    < Design >
    Exterior design
    • The square motif of the sculptured, robust form conveys the image of having been carved from a solid block of ****l, communicating a feeling of strength and presence.
    • The front corners have been angled for an intrepid look and easier handling in tight spaces.
    • The areas around the center pillars and windows are deeply beveled to achieve a sturdy look.
    • The vertically arranged rear combination lights are sculpted and finely detailed.
    • Six body colors are available, including one new color: Atlantic Blue-Gray ****llic.
    Interior design
    • The tough, modern interior provides a space that is solid and stable, yet refined and comfortable.
    • The instrument panel features a sculpted form that facilitates intuitive recognition and operation and giving it a fun, confident feel.
    • The size and positioning of the four irregularly shaped gauges are varied to achieve an energetic, carefree effect.
    • The seat coverings feature a newly developed suede-finish tricot with bold ridging for the main section, with durable, dimpled jersey on the sides to provide a soft feel and a sculpted look.
    • Two interior colors are available: Titanium Ivory and Black.
    < Packaging >
    • The *******ing, smart packaging creates a versatile space inside a convenient body size.
    • Versatile 3-row seating offers plenty of convenience yet the overall length of 4,285mm makes it a breeze to handle around town.
    • The Crossroad’s effective minimum turning radius of 5.6 meters3 puts it at the top of its class4.
    • The rear doors feature a wide opening angle of around 80ο, making it easier for passengers in the second- and third-row seats to get in and out.
    • The seating can be set in a variety of arrangements with easy operation. The second-row seats tilt and slide forward with the pull of a lever located on the shoulder of the second-row seatback, making it easier for passengers in the third-row seats to get in and out.
    • The Crossroad is equipped with an emergency puncture repair kit, replacing the spare tire and securing more space for third-row passengers while helping to make the vehicle lighter.
    3 Measurement based on front corner of vehicle body (Honda calculations)
    4 1.8-liter to 2.0-liter class minivans and SUVs
    < Power train >
    • The Crossroad is available with a choice of two engines, a 2.0-liter i-VTEC and a 1.8-liter i-VTEC. The i-VTEC system further improves on Honda’s original VTEC (Variable Valve Timing and Lift Electronic Control) technology to allow the engine to retard intake valve closure timing under low engine-load driving conditions. Valve timing control is complemented by a DBW (Drive By Wire) system that provides optimum throttle valve control for a major improvement in fuel economy while cruising. This ensures ample low-speed torque combined with outstanding fuel economy.
    • The 4WD model combines VSA (Vehicle Stability Assist system, which includes an Antilock Brake System, Traction Control System, and sideslip control) with Hill-Start Assist—a Honda first—which temporarily maintains brake pressure after the brake pedal is released when starting on a hill to ensure smoother starts.
    • The new Real-Time 4WD system operates as front-wheel drive under normal driving conditions, instantly distributing optimum power to the rear wheels during startup and acceleration or on snowy roads and other times when driving conditions require it.
    • The Crossroad achieves class-topping5 fuel economy of 13.8km/l6.
    5 1.8-liter to 2.0-liter class minivans and SUVs
    6 Fuel economy for front-wheel drive models driven in 10-15 mode (Japanese Ministry of Land, Infrastructure and Transport test specifications)
    < Chassis and body >
    • The tires feature a new, three-part tread design7 that features different rubber compounds for the center and shoulder portions of the tires to achieve high levels of both fuel economy and braking performance.
    • The front suspension features a McPherson strut design for outstanding straight-line stability.
    • In the rear, a compact, reactive-link, double-wishbone suspension helps provide increased space for passengers in the third row of seats. All types are equipped with a rear stabilizer bar.
    • The tailgate opening features a box-type perimeter frame for greater rigidity.
    • Expanded use of strong, lightweight, high-tensile steel contributes to increased rigidity and weight savings.
    7 Standard equipment on 2.0-liter types
    < Advanced features and safety performance >
    • The IHCC (Intelligent Highway Cruise Control)8 vehicle speed and distance control system helps reduce the burden on the driver during freeway driving.
    • The Collision Mitigation Brake System (CMBS)8 provides audio and visual warnings and braking to alert the driver and to help avoid a rear-end collision or mitigate damage and injuries in the event that one should occur.
    • Honda’s Advanced Compatibility Engineering Body enhances passenger protection while mitigating impact on the other vehicle.
    • The vehicle is also designed to mitigate pedestrian injury in the event of a collision.
    • The rear frame features a large cross-section along with two internal impact-absorbing frames. The frames have a polygonal cross-section to enable them to effectively absorb the shock of a rear-end collision.
    • The door mirror on the passenger side features a built-in prism under-mirror, which takes advantage of the prism’s light-refracting capabilities to secure a field of vision twice that of a convex mirror of the same size.
    8 Standard equipment on the 20Xi (4WD) ; factory option on the 18X and 20X (4WD)
    < Environmental performance >
    • All types have been certified by the Japanese Ministry of Land, Infrastructure, and Transport as having achieved a 75% reduction with respect to emissions regulations for 2005.
    • The 4-wheel-drive 20Xi features fuel economy 10% better than Japanese government fuel economy standards for 2010; all front-wheel-drive types achieve fuel economy 5% better than those standards; and the 18X and 20X 4-wheel-drive vehicles9 conform to those standards.
    9 Varies depending on the factory options the vehicle is equipped with
    شكل مقبول وبس مواصفات حلوة جدا فيها وخاصة الردار الامامي ، وحركة المراية الجانبية للاوضاع تحت اكثر.
    محرك صغير عليها وخصوص الحجم الموتر كبير.
    تسلم اخوي عمر
    @elmalghoom@ غير متصل عضو نشيط
    118
    هذي الجيل الجديد من هوندا المسمى في أسواقنا HRV
    طبعاً بتنزل عندنا بالمحرك الصغير علشان ماتزاحم أختها CRV وانسو المواصفات إللي شفتوها لأنها لليابان فقط
    الصورة الرمزية Jaguar R
    Jaguar R غير متصل مشرف سابق
    U-A-E
    6,304
    مواصفاتها رهيبة.... والشكل مقبول نوعا مـــا...
    ولاشي من المواصفات يكون عندنا اذا توفرت للبيع في اسواقنا ...
    والشكل قبيح اجمالا ولكن اللى بالزوائد اجمل قليلا
    الصورة الرمزية Mr.Cayenne Turbo
    Mr.Cayenne Turbo غير متصل عضو فعّال
    الــعــاصــمـــه
    680
    شكلها غلط
    ومن داخل قبيحه بالقوو
    ومثل ماقالوا الشباب انسوا تنزل عندنا بهالمواصفات
    مشكور يامشرفنا
  2. سمارت تقدم escooter......(جديد باريس)
    آخر مشاركة: 22-09-2010, 08:31 PM
  3. بي أم دبليو تقدم الفئة السادسة الإختبارية...(جديد باريس)
    مشاركات: 24
    آخر مشاركة: 21-09-2010, 11:06 AM
  4. شيفرولية تقدم كابتيفا المعدلة.......(جديد باريس)
    آخر مشاركة: 15-09-2010, 01:28 PM
  5. لكزس تقدم RX270 و IS350 F Sport.....(جديد اليابان)
    آخر مشاركة: 28-08-2010, 02:41 PM
