    Cool 2007 Mini Cooper S by Hamann
    كتكوت متوحش من هامان
    وهذا هو المقال الذي يوضح تعديلات هامان عليها :
    Hamann has of course once again taken on the current model. The Brit from Bavaria not only looks different after its visit to the health farm in Laupheim. The Hamann Mini also sounds better, and drives with even more agility.
    One thing is clear: you will attract attention with the Mini, even in standard trim. The exterior of the Mini could however convey a little more sportiness. Hamann can help out in this respect, clothing the little runabout in some sporty gear. The Hamann aerodynamics kit includes a front spoiler to reduce lift, a pair of side sills with integrated, brushed aluminum doorsills, and a two-piece rear diffuser. Visually equipped in this way, it would not look out of place among the starters in the Mini Cup. The Mini draws even more attention as a result of the Hamann flag-design decoration. This decoration is available in silver, anthracite or white. You can even apply it yourself, and it is available for the sides, the hood and the roof. Customers can order the components together (at a discount) or individually.
    17" and 18" Wheels
    Hamann offers three attractive wheel designs for the Mini. The HM4 is a 17" model, which is a handsome one-piece alloy wheel with five spokes, finished in silver, and has the look of a multi-piece wheel. The PG4 design not only looks like it; it actually is a multi-piece wheel. The 18" five-spoke wheel sports a polished lip. Once again a one-piece wheel, but nevertheless boasting an elegant multi-spoke design, we have the ANNIVERSARY I. With its silver finish and its high-gloss polished INOX stainless steel lip on the outer rim flange, the ANNIVERSARY I is available in 18” form, combining great looks with a practical solution as the stainless steel lip is exchangeable and can easily be replaced in the event of damage.
    Sound Improvement
    Improving the sound of their car is one of the most important tuning measures for many drivers. So for sound fetishists Hamann is offering an impressive twin-pipe sports rear silencer, with two round stainless steel tailpipes (each 90 mm in diameter). A sportier air intake sound is created by the Hamann sports air filter, which is available for both the Cooper and Cooper S versions of the Mini.
    Even though the Mini already has very good handling, Hamann saw a need for action in this area too. Hamann height-adjustable coilover suspension promises even greater agility. It comprises four sports shock absorbers and four springs. The suspension can be lowered by up to 50 mm at the front, and by up to 30 mm at the rear. Thanks to its lower center of gravity, the Mini can be pushed through the corners even more like a go-kart than ever.
    Comprehensive Interior Refinement
    Friends of individual looks have virtually free rein in the interior of the Mini. Hamann doorsills made of brushed aluminum invite you to step inside this small car. The Hamann Sports gear knob and the hand brake lever are also made of aluminum. Exclusive, black Hamann foot-mats make the Mini even cozier, in addition to which Hamann offers two interior sets made of exposed carbon fiber. Set 1 is made up of cockpit panels, cladding for two outer ventilation ducts – one on the left and one on the right, the steering column, the airbag and the centrally located instruments, as well as a cover panel for the tachometer and the passenger airbag. Set two includes the handbrake lever, the decorative ring for the drinks holder, the surrounds for the gearshift gate, door handles and frames, the speaker rings, door trim panels (4 items) plus B-pillar cladding.
    الصورة الرمزية بوجاسم
    بوجاسم غير متصل عضو شرف
    Dec 2006
    قطر الخير-دوحة العرب
    1,328
    تسلم اخوي
    شوفوا الفراري في الصورة الثالثه يا ويل حالي بس !
    <<-- نسى الميني :D
    الصورة الرمزية هنادي اسعد
    هنادي اسعد غير متصل عضو نشيط جداً
    فلسطين
    288
    Smile
    شكرا اخي على الموضوع .
    الصورة الرمزية S 65
    S 65 غير متصل عضو فعّال جداً
    عمان
    1,306
    سيارة صغيرة بس رائعة وحبوبه
    والتعديلات طالعة عليها أكثر من حلوة
    أشكرك على الموضوع
    تحياتي {فــيــاجــرا 600}
    مشكورين اخواني على مروركم
    ودام الفيراري عجبتك اخوي uae speed هذي كم صوره لها بالمرفقات
